New web cams installed
mattp_65
Supporting Member
528
187
Aug 16, 2004
Granite Falls, Washington
Hey DsmTuners
Ok so I installed a pair of Web cams in my car and now for the next modification? What should I do next: Upgrade my small 16g turbo first and then dyno tune it, Dyno tune it first w/ my s16g, or get Dsmlink, or should i go in a different direction? My goal is 350-400awhp so any suggestions would help me alot thanks.
If you already have all the supporting mods in place, all you should have to upgrade is the turbo itself. I think DSMlink would be a good investment for the numbers you're looking to make, assuming you have a factory EPROM ECU. If you decide to go that route, paying for dyno time now with the AFC would be a waste of money. You'll just have to tune it all over again with DSMlink anyway. Keep in mind that 400 awhp will be approaching the limits of 660cc injectors with pump gas AFRs.
