New to DSM's Need some questions answered.
defury
129
Jul 4, 2010
Regina, SK, Canada
Just bought a TSI AWD and have a few specific questions.
1. Do I not need an MAF? Some intakes say (no maf) so do I not need one of these? thought it was important.
2. Is this a decent upgrade path?
NGK BP7ES plugs
K&N Filter FIPK
1g BOV
HKS or similiar universal muffler
RRE Upper Intercooler Pipe
2 1/2" High flow cat + piping
Some form of FMIC
3. Brings me to my next point, what is the deal with FMIC's is there a decently priced one? Can't find any for less then 600$ (when pricing in canadian)
4. Are the free mods a good idea?
i.e
2g Waste Gate Solenoid Restriction Removal
Open up I/C inlet
Remove BOV dump tube
5. Brings me to my next question, VFAQ doesn't have working links anymore, are there any decent guides to the free mods?
your upgrade path is going good... but for the fmic... if you are on a stock turbo its not recomended
for the bcs.... http://www.dsmtuners.com/forums/newbie-forum/7696-bcs-mod-restrictor-removal-merged-3.html OR Alex's 2g Waste Gate Solenoid Restriction Removal FAQ
as for the dump tube... its not recomended unless your running speed density or a gm maf and translator, since if you just remove your recirculation tube, your car will run rich....!!!
also for the spark plugs... you should go with the 6 not the 7...!!!
WELL WELCOME TO THE DSM WORLD.... THE KEY TO CARS IS MAINTENANCE...... TREAT IT WELL AND IT WILL TREAT YOU GOOD...!!! HAVE FUN... ITS A REALLY FAST AND NICE CAR YOU WILL ENJOY IT... YOU WONT BE DISAPOINTED... BUT REMEMBER MAINTENANCE IS THE KEY...!!!
YOU SHOULD ALSO BE LOOKING AT PERFORMING A BOOST LEAK TEST... YOU CAN MAKE ONE FROM YOUR LOCAL HOME DEPOT... NO MORE THAN 2 BUCKS... IT WILL CHECK FOR BOOST LEAKS THROUGHOUT YOUR WHOLE TURBO SYSTEM... IF LEAKS ARE FOUND IT IS RECOMENDED THAT YOU FIX THE LEAKS... HERE THE LINK... http://www.dsmtuners.com/forums/new...se-troubleshoot-boost-leak-tester-merged.html or IC Pipe Tester
also what year is your car?
I don't think he meant completely cutting off the bov tube. I wouldn't even consider that being a mod at all. I'm pretty sure what he meant was the tube that extends into the intake. Cut the BOV dump tube on your DSM (2G)
Car is a 1998 Talon TSI AWD with 150,000km on it, everything stock including stereo :D. Got lots of work to do, picked it up for 5g. I will have to do that BOV dump mod, seems easy.
This link here has some helpful links to help guide you not sure if you found it yet Tech Guide - DSMtuners, but I'd bookmark it if I were you;D And I wasn't aware that VFAQ was down I was just on it yesterday;( Gonna have to try it tonight.
To answer your 1st question, yes you need a MAF. The intakes that say 'no maf' are for people that are either running blowthrough(which is when you have a GM MAF and a MAF-T and put the MAF in the I/C pipe), or speed density. But def like every one said, do your maintenences before you even begin to think about upgrades.
