New steering wheel not centered
94Talon2
271
Aug 1, 2002
Edm,
I just installed a new Grant steering wheel and its a few degrees to the right. It can't be the alignment because I got one a few months ago and the stock wheel was centered before I removed it.
How can I straighten it out?
Did you make marks on the steering coumn when you took the old one off, and put the new one on? You may have installed it a few degrees off?
I would say just deal with it..
maybe it is an alignment problem.. who knows.
Originally posted by Defiant
Pull the nut, remove hub, turn 1 spline to left, reinstall. If that's too far, have an alignment shop adjust your steering rod ends.
I did that and the next grove to the left is way off.
What are steering rod ends? Is that another word for tie rod ends?
