New setup...first time on road
bmxrider154
160
5
Oct 25, 2004
Cincinnati, Ohio
Got the new turbo setup installed (Scm5031e) along with a whole list of new goodies listed in my mod list. I am currently breaking in the new clutch so i havent been too hard on it. I have logged some 3rd gear pulls at 10psi just to kinda check the new timing and afr maps with the chip. Everything is perfect, timing is dead on when at WOT, and hardly any present knock. The reason im posting is it is cutting out once full boost is reached (10psi), just kinda stuttering like maybe spark issues. Keep in mind this is the first night out babying it, i will post some logs as i get it some miles on the clutch. Another quick question is concerning the maft in which i hard wired, im geting an airflow CEL as well as the famous idle surge(didnt have before teardown). Thanks for reading and any suggestions greatly appreciated.
Bryan
The main problem is the idle surge that started after installing the turbo and everything. Didnt surge at all before and logger says idle motor is working properly.
I figured out the problem, i had one of the wires mixed up when hardwiring the translator. So i fixed that and thew in some new plugs with a .028 gap and runs perfect. The idle surge was just due to a very high idle that the isc couldnt control.
thanks for the help
bryan
