New logs
JDR7919
301
Jan 1, 2005
Titusville, Florida
Hey guys Im trying to work on my pump gas tune.
I have not been able to change fuel much because my wideband is acting up and showing Im running lean.
I have been adjusting timing and running about 21psi. 3bar looks pretty good
I was not able to do I full 3rd gear pull.
Let me know what I should look at.
I would like to run about 25psi if I can get there.
Thanks
Have you tried using the other AEM inputs? I know the AEM is not the greatest with DSMlink.
Do you have a gauge with the AEM? If so, how does it compare to the logged values?
Also, I would recommend getting the V3 software and working with that if you can. It's a much nicer interface.
Do you have an AFPR and is your fuel pump rewired? If not, I'd work on both of those items.
Yes
Dsmlink and guage match. I have looked for exhaust leaks cant find any. I know its off because its saying im running high 11 a/r on pump and Im not really knocking enough to be concerned.
Its showing the same a/r as when I was 110 oct a few weeks ago with alot more fuel pulled out. Now I have added fuel with no change.
I down loaded it the other day just have not had a chance to look at it.
Do you have an AFPR and is your fuel pump rewired? If not, I'd work on both of those items.[/QUOTE]
Yes I have afpr and rewired 255
It will be very difficult, if not impossible, to spot exhaust leaks. You'll need to run some seafoam through the motor, or have a shop perform a smoke test. That's the only way I was able to find out that my flex section was leaking.
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
