New Log
1glaserturbo
591
3
Feb 12, 2005
Creve Coeur, Missouri
Posted this up on DSMLink but it seems that nobody has taken a look at it yet for any help. This is basically just a base run, at 14.5lbs in third gear. I'll update my profile here in a second to give you exacty what I have, but this is the jist.
FP3065
Built motor on 9.0:1 compression
43.5psi (Needs to be lowered to 37) base fuel pressure
5* BTDC Base timing
93 octane
1000cc FIC INjectors
Rewired MKIV TT supra fuel pump.
Any help or adivce would be awesome :thumb:
I'll verify that he has DSMLink.
First of all, make sure you calibrate your MAF. Was there an issue with your gas pedal? Your throttle position dipped for a second near the end of the pull. It looks fine for a WOT log, although your fuel sliders are a little suspect. Was that tuned with a wideband?
