New Jpipe
subie22
354
Feb 28, 2007
Tobyhanna, PA, Pennsylvania
Ok so i am getting tired of the boost leaks that this new jipe i got created. So i have been looking at getting some new, but unsure what to get. I am looking for something like the stock one, but instead of the outlet comming out in an angle, i wanted it to come straight down then just use a coupler to connect it to my intercooler piping. So any ideas on what i should get it would be great. I got the jpipe i have now from extreme psi, but i dont think it will work out to well.
Talk to JMFabrications, I am sure they can make something for you at a decent price that is exactly what you are looking for. I had short route piping made by them and it's great. Mine comes off the turbo to that "J", then goes straight down and over. Other then that, my only suggestion would be Dejon
yes i just called them, they say they dont really mess with jpipes, but i guess they will be getting involved in it. But i just need something that doesnt have such a crazy bend in it. Makes me sad...
Want me to get a pic of how they set mine up? My car is not running full right now so I can easily give it back to them to duplicate/copy if it's what you are looking for.
yea dude if you dont mind that would be great. Not to sure how you want to send it but, email i guess or post it either way.. Is cool.
I will just post it up here later when I get the chance. The J-pipe side of my FMIC is two pieces though. That J-pipe piece I described, then the other is like a huge "U" since my FMIC core's outlets are on both sides not behind it (if that makes sense?)
2nd Piece:
Coming off the compressor housing:
The "J" and then leading down and around my fan:
Ending section of my "J" pipe which then connects to that "U" pipe which I posted earlier:
Hope this helps, if you need more pictures let me know.
the right allen bolt, was it hard to bolt in since the exhaust manni is right there, Let me know, i like it but i think i will just need it to come straight down like the most of the jpipes are i just need something not so extreme on that one bend. Thats why i asked if it was hard to get to. But it looks fine to me.
I have these hex wrenches/bits that have a huge handle on them. So it's not difficult for me to get to them. If you tried with a standard allen key I am sure it would be quite difficult.
As for it being extreme, I find it better to keep the pipe as far away from the exhaust manifold as possible. Especially if I am to consider upgrading to an external wastegate more room to add stuff.
This is the j-pipe from Dejon. It opens up to 2.5'', worked great for me. That hose on the end was just a make shift coupler i made outta radiator hose.
BTW: I'm sellin it if your intrested PM me.
sexydsm hit me up with a link so i can see what you are talking about. On the hex bits.
  • Wanted 6 bolt NT water pipe
    • chrisman287
