dwdsm
- 595
- 45
- Apr 28, 2005
Scenery Hill,
Pennsylvania
I have three big problems with my new motor/car (6-bolt no BS)
1. I think the oil pressure is way to high. 35-40psi at idle and well over 100psi under boost.
2. clutch is weird and gave out on me three times yesterday even after my friend Mario and I worked on it and bled it Sat. evening.
3. The seals are leaking like crazy! I may of made the mistake of using ultra grey along with gaskets for everything...The topline gaskets seem so cheap to me I thought it would help.
Answers.
1. I may pull off my filter housing and port my bypass some more to lower the oil pressure.
2. replacing the master and slave cyclinders. Fu@# it I got so much into it what another $150
3. Hope fully Answer #1 helps but mario and I need to see what the problem is. I'll take the timing side down to the belt only and start it to see whats going on..
What do you guys think?
Answers.
