Needle stuck at warn only lights- apexi EGT gauge pic inside
sadc
274
Feb 17, 2008
Kapolei, Hawaii
Anyone else have this problem? I have a apexi EGT guage. Idk one day it just stopped working. When I do race it does flash the warn light.But the gauge does not do anything. Lmk
I had to pull the Cover off of Mine, The needle slipped off the teeth on the shaft. You could barely even tell it lifted, until you could physically push down on the needle. I am also on my second one. For whatever reason after a I fixed the first one The teeth on the needle stripped out under heavy boost. Talk about FAST spool up :dsm:
What I am saying is either the Needle slipped up off the Cog and is not getting any bite to move, or the plastic teeth have stripped. I had it happen to my A/M Boost gauge and my Temp gauge on my SS. Is your sensor still sending a signal to the gauge?
