Need thicker Head gasket
RoaSted
67
Feb 11, 2004
Pickens, South Carolina
whats up. I need a thicker head gasket and was wondering if there are diffrent kinds out there and which would be better for me. If you could give me the price range of the gasket too. Working on my car and gettin the last few things that i need so i can put my motor back in. Taking me a while but learning a crap ton! Thank you for everyones help. :thumb:
I have the turbo 420a ( dont know if u need that info.) :confused:
levi :dsm:
For a gasket that serious id go w/ factory suprisingly there not that expensive.... :dsm:
I think he wants something thicker than factory to lower the compression.
olmytsi said:
Go with a mitsubishi 4 layer headgasket.
That would be a great suggestion, except that he has a 420a, not a 4g63. Pretty sure Mitsubishi doesn't make gaskets for chrysler engines.
How much would that 4 layer gasket cost me? And where could i pick one up at? Yeah im wanting something to lower my compression down some more. Thanks for the help.
taking the motor to the machine shop in a few days :thumb:
do i even need a thicker head gasket... is it nessacary that i get one?
So wait, you are taking the motor to the machine shop and you want to lower the compression with a head gasket.
If you are going to be using different pistons, then just have them orderd with the compression ratio you want.
:confused:
