sillylepricon37
- 128
- 1
- Dec 17, 2008
Rapid City,
South Dakota
I don't know if you all have read my other threads but the problem is still not resolved.
I am pulling timing really bad and my manifold glows cherry red; So does the Turbine housing. The car feels like it has no power and my wastegate is opening too early making this hilacious noise.
I have replaced the following.
-Ecu
-Knock Sensor
-Hooked the wastegate up right but it still makes that noise.
-Intake sounds like a turkey (Probably Compression Surge)
-FPR was un hooked, plugged it in.
-Spark plug wire was off, put that back on.
-Checked the turbo, seems to be fine.
-I get 100 miles to a tank of gas.
-A cold start up, and it wont rev above 2k.
-I can go 1 block down the road and the manifold glows.
-White Exhaust smoke. when its cold out. A lot of It.
-No check engine light
-No Codes
-Disconnected the exhaust and still the same problem.
-Mechanical Timing is dead on.
-Spark Plugs are in the correct firing order
-Threw on some RC550cc injectors and still the same problem except the idle jumped to almost 3 and stayed there!?
Tell me what you think. Im a little confused and cant come up with anything else.
-Ecu
-Knock Sensor
-No Codes
. He came over one day and checked the timing. I gave him a 1/2 in ratchet and he slowly turned it and said Wow It is so dead on it doesnt get any better. It doesn't even come from the factory timed this good. So that was that. I can tell him what you are saying but i don't think its the timing
