Need some help with oil cooler.
purplehazetsi
277
Oct 14, 2002
Berlin, Connecticut
Ok, im doing a full 1G 6 bolt rebuild with a huge amount of mods. Now im looking to replace my blown 91 oil cooler. Im looking to switch to the 90 style. BUT.... getting the 90 housing is easy, i might just get a universal oil cooler from summitt or something. Now im going to run AN fittings, and SS lines from the housing to the cooler. Is there any special adapters i need? I heard i need an adapter for the housing to the SS lines. thanks
From what I've gathered all you need is the metric-AN fittings, so you can screw into the housing, then use an fittings for the rest. You'd need two of the metric, supply & return. Hope it helps. There is a big thread on this somewhere, it like "oil cooler pics" or something. :thumb:
2 M16x1.5 to AN adapters Jegs# 23-FCM2608
1 -6 90-DEGREE HOSE END Jegs#23-FCM4032
1 -6 45-DEGREE HOSE END Jegs#23-FCM4022
Those numbers are from my order and are the ones above. You could get two 90s, 45s, or even 120s.
