need help...
CT DSM 06114
42
May 26, 2004
Hartford, Connecticut
don' know where else to put this. this is the only section that deals with electrical.
anyways, car won't start...again.
as i was pulling into my drive the car just stalled out. since i have push button start, i pushed. the starter is rotating but no start. i open the door to push the car...the seat belt never moved. i had to unhook the seat belt manually to get out of the car. i pushed the car to my spot and started probing around with a voltameter. i have a good charge, starter cranks, atm gauges light up with the swith. my electric fan which is powered by the fuse box in the cab, does not work. my turbo timer does not light up, afc same thing. i check all the fuses under the hood, all have power to them and fuses are in working condition. i had problems with my turbo timer in the past, so i removed it today. it put back to stock (no turbo timer). if i hot wire the fuel pump, it works. i tryed hot wiring the fuel pump and crank the car and still won't start. i have no power in the coils or transistor. mainly due to my ignition power not being there. i go ahead and check my fuse box under the dash and no power there. windows won't move, horn don't work, ignition switch won't power anything. i have no power in the cab what so ever...once again...
please help as i need this car to get back to work tomorrow.....thanks in advance
tony
Check double check and re-check all grounds and fuses.
Other than that I find it funny that you post about your NT in the 4G63 Tuning & Engine Management forumROFL
just updated my profile.....1990 talon awd.
how can i check the fuses in that cab, when there is no power in there?
