Need help with these injectors
Jordan_40
68
Nov 5, 2013
Breezewood, Pennsylvania
I have searched for about an hour and a half and can not figure this out. I traded my blown up 420a for a set of injectors and a brand new walboro 255lph and AFPR. But I can't figure out exactly what size these injectors are. Guy have them to me in a precision 1200cc case but said they were 575 and not precision injectors. Only numbers stamped anywhere on these injectors are, 105f, 39264, 3102
not sure if these are a match but this is what ive found so far....
siemens deka
Mfg., Part number: FI 11402; Part number on injector: 3102
Flow Rate: 575cc/min at 43.5 PSI
Flow Rate: 55LBS/HR at 43.5 PSI
Resistance: 3.2 Ohms
Voltage: 8-15 Volts, Nominal 13.5 Volts
Amperage: Peak 4.0 Amps/ Hold 1.5 Amps
Pressure: Min. 36 PSI (2.5 bar), Max. 87 PSI (6 bar)
If I put a picture up would that help?
And on top of that if they turn out to be 575 that wouldn't be enough to flow a 20g setup.
Check on the part the harness clips to, on the sides it may show the flow rate in lbs. Post pics
Already looked there's just 00. He said they were 575 Delphia injectors but I was just checking so I know what to enter in on my ECMlink
