need help with Synchro PLEASE!!!!
awdtalon21
152
Mar 4, 2007
St. Charles, Illinois
im in the process of trying to replace my synchros and i dont know how to get the bearing sleeve off, or the 3rd gear.
<a href="http://img262.imageshack.us/my.php?image=image019hy3.jpg" target="_blank"><img src="http://img262.imageshack.us/img262/6849/image019hy3.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a><br /><br /><a href="http://img604.imageshack.us/content.php?page=blogpost&files=img262/6849/image019hy3.jpg" title="QuickPost"><img src="http://imageshack.us/img/butansn.png" alt="QuickPost" border="0"></a> Quickpost this image to Myspace, Digg, Facebook, and others!
<a href="http://img413.imageshack.us/my.php?image=image020vs7.jpg" target="_blank"><img src="http://img413.imageshack.us/img413/1662/image020vs7.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a><br /><br /><a href="http://img604.imageshack.us/content.php?page=blogpost&files=img413/1662/image020vs7.jpg" title="QuickPost"><img src="http://imageshack.us/img/butansn.png" alt="QuickPost" border="0"></a> Quickpost this image to Myspace, Digg, Facebook, and others!
<a href="http://img441.imageshack.us/my.php?image=image021yh0.jpg" target="_blank"><img src="http://img441.imageshack.us/img441/2976/image021yh0.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a><br /><br /><a href="http://img604.imageshack.us/content.php?page=blogpost&files=img441/2976/image021yh0.jpg" title="QuickPost"><img src="http://imageshack.us/img/butansn.png" alt="QuickPost" border="0"></a> Quickpost this image to Myspace, Digg, Facebook, and others!
I edited your picture with the instructions needed.
Use at least a 7-ton press; I would reccomend a 20-ton press to do this gently and easily.
Follow the instructions written in the picture. If you have any more, just add them to this thread, and I will help you through it.
Large text box reads:
"Place your gear puller in between the 3/4 hub and 3rd gear synchro with the curved side of your gear separator facing the 3rd gear synchro, and the flat side facing towards the 3/4 hub. Pull gently, you may trash the synchro or damage the 3/4 hub. Be extremely slow in pressing this part off and be sure to use a Red ScotchBrite pad or 600-grit sandpaper on the shaft after the parts are removed to clean the surface. Then be sure to use some clean paper towels and a can of Brake Clean prior to re-lubricating the shaft and pressing on your new parts."
Small text box reads:
"Be sure to clean the shaft surface after taking off the 4th gear bearing spacer and relubricating before pressing this part back on. It sucks to take it off sometimes."
I have had good luck and bad luck removing this part sometimes. Sometimes you trash the 3rd synchro and the 3/4 hub/slider, and sometimes it presses off quite nicely. It will be a smoother process when you use a larger hydraulic press.
I dont think the gear puller will fit between the 3/4 hub and 3rd gear synchro. Do you know what size puller i need?
I usually use OTC 1124 = 1/2" - 5 3/4" span
eBay Motors: OTC 1124 Bearing Splitter 1/2in 5 to 3/4in Bearing Tool (item 300216556527 end time May-15-08 08:33:10 PDT)
OTC 1124 - Bearing Splitter 1/2 - 5-3/4 Capacity
Amazon.com: OTC 1124 1/2" to 5-3/4" Bearing Splitter: Automotive
This tool is extremely helpful in removing every part from your transmission.
If the 5th intermediate gear is ever an issue in removal, I reccomend using:
OTC 1123 (medium bearing separator):
Large OTC Bearing OTC Bearing Splitter OTC-1123 - eBay (item 250246165273 end time May-15-08 13:52:48 PDT)
with:
OTC 927 10-ton push/puller:
OTC 927 10 Ton Push-Puller - ToolKing.com
or
OTC 1122 (small bearing separator):
OTC 1122 1/8" - 2" Capacity Bearing Splitter - ToolKing.com
or
OTC 4518 push/puller set with small and medium bearing separators:
OTC 4518 Stinger 5 Ton Bar Puller/Bearing Separator Set - ToolKing.com
Good luck,
dude i bought the tool you told me to get and i still cant get it off.
Well, I did state that sometimes it works, and sometimes it destroys the 3/4 Hub.
Replace it with a new 3/4 Hub and Slider with Synchros and springs and Keys:
1 x MD747647 (H.D. 3/4 Hub and slider with synchros and keys)
2 x MD742445 (H.D. 3/4 Hub and slider key springs)
Good luck,
here is what happend
<a href="http://img442.imageshack.us/my.php?image=picturezb3.jpg" target="_blank"><img src="http://img442.imageshack.us/img442/9917/picturezb3.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a><br /><br /><a href="http://img604.imageshack.us/content.php?page=blogpost&files=img442/9917/picturezb3.jpg" title="QuickPost"><img src="http://imageshack.us/img/butansn.png" alt="QuickPost" border="0"></a> Quickpost this image to Myspace, Digg, Facebook, and others!
Well, you can do a few things, press it off using your bearing separators, getting under the broken hub; grinding a notch line around the 4th gear spacer and using the bearing separator on that, and pressing it off; trashing the Input shaft by cutting off the shaft and spacer to save the 3rd gear; or:
Bring it to a professional and let them remove it for you on a 20-ton press.
Sometimes they break, but I have only broken 1-2 like yours. I ended up getting them off, but it was definitely alot of time wasted.
i just want to make sure im doing it right. what is the 4th gear spacer, can you show me on the picture please.
The picture I attached in post #2 -- it is the metal sleeve that is pressed onto the input shaft, with the right-hand-side arrow pointing to it.
You guys are doing it completely wrong. The gear below the hub is 3rd gear and it is a floating gear. Just press out the 3rd gear and the hub and needle bearing sleeve above it will come off too. You can use a puller, but it needs to be a big one.
Jack
Jack is right, and I was a complete idiot in this post -- I gave the wrong location for removal of the gearset. With a 20-ton press, this location is a snap to remove the 3/4 gearset.
The proper location for pulling the gearset is at:>
