need help with finding amp wiring kit
firecruiser
Mar 29, 2008
Chambersburg, Pennsylvania
hi yall, this is my planned setup. If you could please give me some suggestions on wiring kits and any changes i should make in my choices.
also, could you tell me will the 6x9's fit in a 96 eagle talon w/o infinity system.
1 065G51244 Boston Acoustics G512-44 DVC 12" 4-ohm DVC Component Subwoof
1 489AP1200 Profile AP1200 200W x 2 Car Amp
1 105KDHDR30 JVC KD-HDR30 HD Radio/CD Receiver
1 489HA1040 Profile HA1040 80W x 4 Car Amp
1 130TSA1782 Pioneer TS-A1782R 6-3/4" 4-Way Speakers
1 113KFC697E Kenwood KFC-6972ie 6"x9" 4-way Speakers
1 065G51244 Boston Acoustics G512-44 DVC 12" 4-ohm DVC Component Subwoofer
chances are your stock speakers are not 6x9s to begin with, you said you don't have the infinity option, so chances of the rear stock speakers AND mounting are NOT 6x9s. so caution there. you probably have 6.5" back there, with the nice 6.5" mount that a lot of us infinity option owners like to have :D
and even if you did have 6x9s, most "quality" 6x9s have deep mounting depth because of the bigger magnets and chances are you will have to bang the fender, usually more than just little.
you are running subwoofers, a proper setup have the rear speakers for rear fill, meaning when its PROPERLY tuned, chances are the gain on the rear will be minimum, and you will hardly hear it, but that is the correct way.
this means 2 things, you wasted money on buying nice 6x9s, and wasting money and power from the 4 channel amp that you got. why buy things you will hardly bring to their true potential.
if you already bought that 4 channel amp, which i am assuming you had planned to power all 4speakers+tweets from components. bridge them to make 2 channels to power the components up front, and power the rear speakers from the deck. after tuning, the lower amount of power the rears get from the deck will sound similar to as if you had used the 4ch. amp powering them but tuned properly for proper front soundstage, see what i mean by wasting money.
as for wiring kit, shoot walmart has some nice thick gauge kits, with splitter. ive used the wiring kits from them and its been years now and all the 2gs ive installed them in (over 5) are still working well. should be more than enough for the profile amps.
