need help with a/f gauge?
flipnotize
May 6, 2004
fayetteville, North Carolina
hey wsup. my air fuel gauge use to fluctuate. now it js sits on lean. green.. doesn't move. js stays there.. what could be wrong with it... it doesnt fluctuate at all.. can u guys help me out.. thankx...
heres my 2 cents...it may not be what u wann a hear but o well. ditch that stupid AF gauge and get an EGT gauge. its more accourate and it actually tells you what it gouing on inside your motor. thats my opinion. as for wht your gauge isnt working, i dont kno.
thankx man. if there is anyone else that can help me. hit me up. take care
actually, the only thing i can think of is to just double check all the connections, ie ground, power, and the ones to the o2 sensor.
I agree, but the lean green is showing because the voltage is low the gauge runs off the voltage being .1 -.99 or something like that. Lean being close to the .1 volts rich being .99volts stick a volt meter on it and see what the signal wire is reading.
Drew
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
