need help (video)
Talonnightracer
Dec 23, 2005
Perrysburg, Ohio
dont know if its my boostleak or what its sputtering really bad geting on the gas and is running rich
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i69.photobucket.com/player.swf?file=http://vid69.photobucket.com/albums/i51/mxracer20/001-1.flv">
Did you check is your mass air flow sensor is bad? check if you have major boost leaks and also check you spark plugs.
i had a fouled spark plug and it caused a dead cylinder under boost.sounded the same pull the plugs and check them.check the wires to.(spark plug) simple easy fast check
