I need help diagnosing engine noise (VIDEO)
Drewcool2
234
Jun 15, 2003
Downingtown, Pennsylvania
A little while back I blew my headgasket, and while the head was off I had it rebuilt and I put in some FP2 (Comp) Cams. We put it back together with a MLHG and ARP studs. All was fine for a few days until the motor started getting noisy, seeming to come from the head after a 45 minute trip. It got progressively worse and I noticed that at idle, the RPM's would drop a little when I pushed in the clutch. On the way back from my trip I had to drive very slow to keep the RPM's down under 2k since things were so noisy. Out of gear, if I let off the gas the rpms will drop very quickly, especially with the clutch pushed in. I also notice some leaking oil from behind my harmonic dampener, and it seems a little wobbly. If I look at my oil, there is graphite-like metal on my dipstick which all came from this trip.
My prediction is I was loosing oil pressure in ares which somehow instantly led to signs of crankwalk, and noisy lifters. My stock oil gauge always had good pressure between the two marks - not like I trust it.
Can you guys watch this video, and let me know what you think happened here.
http://www.drewq.com/video/talon%20motor%20noises.AVI
I would start by pulling the timing belt cover off....check you balance shafts, I noticed you had some heavy vibration judging my the oil hoping around your valve cover, The "graphite" like stuff on the dipstick may be bearing particles from the b-shaft bearing. The sound on my computer SUCKS so i couldnt really judge the sound. Worst case..... Rod bearings.... When these suckers start to go a good symptom Is a very noticeable lack of power W/ horrible noises... Drain the oil with a strainer, and see what you got in there. Keep us posted with your findings.
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
