Need Help Reading Compression Test Results
99OZDSM
267
44
Jun 16, 2007
Virginia Beach, Virginia
As the title reads. I did both dry and wet tests and got these numbers starting from cylinder 1, near the timing belt to cylinder 4 towards the battery. Also, take note that these numbers are from a fairly warm engine, about 15 20 mins shut off so the results are not from operating temperatures.
Dry
C1-150
C2-165
C3-195
C4-180
Wet
C1-180
C2-210
C3-230
C4-205
Correct me if I'm wrong but the increased wet test results mean I have a worn or damaged ring or cylinder wall? Any and all advice is greatly appreciated.
Dry
C1-150
C2-165
C3-195
C4-180
Wet
C1-180
C2-210
C3-230
C4-205
Them are some pretty wild numbers there. And you will see a jump in compression with a wet test no matter what. Did you by chance use a cheap gauge? Or do you have high compression pistons?
I'd put my money on cylinder wall wear.
The wet test numbers are within factory spec (170 - 255psi, <25% variance). Are these factory pistons?
