need help picking...
mattspyder
1,046
Nov 2, 2004
del taco, Wisconsin
well hes what ive come up with, its either the evo III big 16 g or this turbo.....http://www.bullseye-power.com/product_info.php?cPath=37&products_id=59
the to4b comes out to like 824 with final tax and all that crap and the evo 3 with the install kit final is like 724. which one in your eyes is a better street turbo. i dont race on the track or nothing. just maybe once in awhile on the street. should i go the extra hundred bucks and get the t04b or go with the evo 3...???
I say go big or go home! Not to mention, speed is contageous, once you get the Evo3 the chances of you wanting something bigger later is pretty high and you can pay 100 now or a lot more later. Not to mention a turbo that has a longer spool will cut down on wheelspin if and when you do run it hard. Make sure you have all of your supporting mods in order though, I dont see a pump, injectors or anything fuel related in your profile, make sure you have those first. :thumb:
I started a thread just like this awhile back. Same exact question.. Take a look there is ALOT of information and pictures.
http://www.dsmtuners.com/forums/showthread.php?t=138149
I can honestly say you will be better off going with the t04b from bullseye-power.com. If you dont want to hafto upgrade later, I would go with the t04b. I had a small 16g, Then was unsure if i should get the b16g or the t04b, I went with the b16g and kept it for 5 days before upgradeing to the t04b. Wish I would have just went with the t04b before buying the other two turbo's brand new.
Just take a look at that thread, Towards the very end is where there is alot of information about the turbo as I am not the only one that purchased it.
Like said above, You will need the supporting mods for either turbo, In my opinion.
