Need Help On 2g Dsm!!!!
98turbo
296
11
Aug 22, 2004
Mobile, Alabama
Ok guys, need some help. Installed 14b this weekend, along with a safc2. As you know, I lost a boost source taking out the t-25, so I T'd the vacuum line off the bov to make up. Well now my bov isn't venting and here's the weird part, it's blowing off out of the intake....??? I'm going to list everything I did/installed, if you can help, please do...
This all occured in one day...
Installed 14b with evo3 manifold, new o2 gasket, new turbo to manifold gasket, new turbo bolt, new ngk plugs, safc2, did the initial setup thats all, installed water temp gauge, changed oil and coolant....and new clutch(day before)
if the blow off is not opening and you say it is "bowing off out of the intake" then im pretty sure that is compressor surge i would suggest not driving the car till the problem is fixed as compressor surge is very hard on your turbo. what kinda bov do you have? and is it adjustable? check to make sure the vac lines are not blocked at all. alot of people have there boost source t'd into the bov line, double check to make sure the bov line is still going to the intake manifold and boost source line is t'd into bov line
