Need help for HKS Peak/Warning/Hold Boost G. Install
Syndicate
130
Jan 22, 2004
Apopka, Florida
Hay!
I recently ordered a hks 60mm boost gauge from rhdjapan ( Pretty darn good company on ebay ) .
Anyway the HKS gauge I wanted which is no longer in production I ordered , Alough on HKS's site they have the wire lay out yet do not tell what wire is what ( They show the cars ecu pin out ) . Now by all means I could just probably order the instructions but they charge for them .. yet all they do is fax you them . GOOD OLE HK$ !
I wanted to see if someone has this gauge installed who can tell me the correct wires .
Red / orange / Black / Yellow ( red stripe ) .. Which im guessing is same as all others 12v , illumination , ignition , ground
There are Purple red stripe, Blue red stripe and brown red stripe .. Not sure what is what the blue with red stripe also has a splitter which goes into 2 sep wires . ( inj pulse maybe )
If ANYONE knows of someone , or has a friend who has the english instructions ( pretty sure thee is only 1 set instructions for all hks meter gauges which is one double printed ( both sides ) sheet of paper. I do have the sheet but its all in japanese . I looked at it long and hard but unfortunately no subtitles appeared even after several beers.
Thanks
-b
