need help finding a trany rebuild kit
mccalla77
Jun 2, 2011
fort stewart, Georgia
i have a 99 GS and need a full rebuild kit. everywhere i look they say their kits are only for 95-97. im new to DSMs so im not sure if there is a difference in the year/trany. I have checked jacks and they don't do rebuilds on 95and ups due to the week internals. any help would be appreciated.
What information have you found so far for rebuild kits? I can take a look at them and give you more information.
New Venture A578 5 speed FWD Manual transmission parts and overhaul kits - Drivetrain.com
You would be using the rebuild kit with synchros: DTSBK414WS, along with the dog & spring kit, small parts kit, and diff bearing kit if necessary depending on your transmission wear.
The disassembly of the trans is not too bad, but it can sometimes be a pain to remove the input shaft outer roller bearing snapring from the case, as well as seperating the input shaft outer bearing from the input shaft. Miller Specialty tool makes a special press tool pallet fixture to seperate the gear cluster from the transmission case without damaging the gearset.
thanks for the help. hopefully it will be done next week. i need to get this back on the road. i miss driving it:cry:
  • Wanted 6 bolt NT water pipe
    • chrisman287
