NEED HELP FAST. turbo fitting
boredog
52
Nov 14, 2008
wichita, Kansas
ok so i was installing an o2 dump and evo 3 mani on my car today started it up and all my oil came out of my ss oil line. there is a 90 degree fitting on the turbo with a male and female end. the female end is a rotating nut that screw onto ### looks to be a a/n fitting that is on the turbo. now does that fitting have to be replaced or can i directly put the ss line to the AN fitting with some teflon tape?
What? Don't use teflon tape, that's about all I could understand enough to reply to..
If your reffering to an ss oil feed line with the banjo bolt...You need to replace your two copper crush washers..I just had this problem..Go to you local mechanic, and get 3/8 copper crush washers..They use them for breaks..My guy charges me 50 cents a peice...If you go to you local auto parts store expect to pay over 6 bux..
sorry i guess that was kinda hard to understand.
this fitting
bent a bit when i was putting the ss line bk onto it. when i turned the car on 4quarts gushed from it.
now instead of tryin to find a replacement which its saturday and would be hard to do can i install the ss line onto this fitting.
instead of replacing?
Ok a little tip for next time..Do not remove any of the lines connected to the turbo..Loosen them at the other end....It looks like you have lost you nut that connects the two peices..At least I'm pretty sure mine has some kind of nut on it..Lemmie run down stairs and see if mine has a nut..
EDIt..I ran down stairs and took a look at mine..MY ss line does not have that 90 degree fitting on it..It's basically a nut that screws onto the fitting on the turbo..
