stratplayer24
- 63
- 5
- Sep 21, 2008
Pittsburgh,
Pennsylvania
To start off, I think I have a boost leak. When ever I get into boost it sounds like its just leaking all out. It's just a loud like hiss. I have a front mount and have tightened all the coulpers pretty tight butijust cant find where theleak is. Is there something I could do to narrow where It is?
Second of all, I had my tyranny rebuilt,flywheel cut and a new clutch. Whenever the car is cold it'll shift as smooth as s Honda. But whenever I drive it after It warms up it'll be very difficult to shift. Like I'm not even pushing in the clutch. And when I'm stopped and try to shift Into first gear ill have To force into gear which I know Is not good. the clutch Is adjusted right, I know that for a fact. Does anyone have some Input? Also after the car warms up the gears will whine really badly.
Any help would be appriciated.
. Let us know what you find.
You need to either have your intercooler pipe ends bead rolled so that don't come apart as easy or you need to try using some t-bolt clamps if you are not already. To be absolutely sure you should have the pipe ends bead rolled and use the t-bolt clamps, but sometimes you can get away with just using the t-bolt clamps.
