Need Help and an answer today so i can get part from dealer please !!!!!!!!!!
xxking9
31
Nov 20, 2011
richmond, Virginia
Hello, i have tried to download caps but i cant due to having windows 7 and it says something about the program not being able to run on 64bit or whatever, i have a 1992 awd turbo eclipse automatic i need to get the part from the dealer if they can get it, on the transmission its the round sensor with one wire coming out of it that goes to a two pin plug, the wire came out of the sensor in the trans i need to know what the part is really called, and or part number if somone has caps. please let me know asap trying to get it before they close, i also just bought a full tranny master rebuild kit, and new bands, which was like 400$ and i can only return it if i havent picked it up yet and i still have to pay a 20% re stocking fee i would much rather only lose 80$ instead of 400$, if i cant get this part trans wont run and i will be out 400$ and still have a non running car please help!!! thanks mat
That sounds like your rev lock out. If you can get us a pic Im sure I could tell you for sure. As far as I know there are only a couple plugs. 1 is your solonoid plug, but that looks like the exact same plug for your rad fans. Then you should have a rev plug, to turn on your rev lights and tells the ECU that your in REV. I dont think there are anymore tho. If you say the wire broke, why not just put a spade on the wire and plug it back in? But if you say the wire came out of the sensor, its likely your rev lock out. But a picture would confirm it.
If it is the big black plastic sensor on the front (like 3-4" diameter), it's called the Kickdown Servo Switch/Sensor.
Kickdown servo switch is it!!!! , dealer doesnt have it ebay doesnt have it i have called 1047493 tranny parts places anyone have one or know where i can get one i know this trans is rare which is making this a pain
<a href="http://s1086.photobucket.com/albums/j450/Xxking9/?action=view&amp;current=kickdownservo.jpg" target="_blank"><img src="http://i1086.photobucket.com/albums/j450/Xxking9/kickdownservo.jpg" border="0" alt="kickdown servo"></a>
If you are having that hard of a time finding it, you can always buy a used tranny for a couple hundred bux and put the servo into your current one. Then you can always rebuild the used one u bought with your kit and have a spare tranny thats freshly rebuilt and ready to go. All u would have to do is swap the trans and the servo.
But thats what I would do. Dont know if thats an option for you. Extra parts are always good to have, and u can find auto transmissions all over since the bigger demand is the 5sp manual.
If it's a 92 car, it should be part number MD736636 which would run $46.50.
If production date on the car is after 07/01/92 it would be part number MD752472 which would run $42.40.
Unfortunately, Mitsubishi is not showing MD736636 anywhere in the country at the moment (we might be able to order one in from Japan, but it would take a bit).
MD752472 is currently available with 3 in stock.
Both come with the outer o-ring seal for the switch.
Hope this helps.
Josh
Ah yes, the ever-disappearing parts game. Pretty soon these cars will be obsolete for most people.
