Need every part needed to run a feed line from the oil filter housing.
mitch26753
354
Aug 8, 2007
ridgelely, West Virginia
Well i am droping in my motor finally! I need to know what all fitting i need to make my own 4an feed line. I look at slowboy and they want $50 dollars, which is kind of high. You can purchases the parts seperates and save alot of money! SO what all fitting do i need for a 16g going to a forward facing oil filter housing? i am getting a 24 inch 4an line. I know i need a banjo bolt, but which size 10mm or 12mm? i need 90 degree elbow that take the 4an to either 1/4" or 1/8", which size is that? any help would be appreciated!
No need to do that. Just purchase it here from Bonehead Performance, cheaper than Slowboy and way better customer service. I've purchased quite a few things from them in the past.
eBay Motors: Stainless Turbo Oil Feed Line for 2G DSM 16G Eclipse (item 180214958832 end time Apr-11-08 07:02:53 PDT)
Good Find my man! I am wandering though why it says that the adpater screws into the turbo? It's suppose to screw into the filter housing right? I hate ordering off these ebay companys half the time they dont even know what there selling, let alone if it fits.
Yeah, I think that was a typo of some sort. Bonehead Performance is actually a supporting vendor on here but like most reputable vendors do, they also market their products on Ebay. Of course the banjo bolt is for the turbo and the 90° adapter is for the oil filter housing, you shouldn't have any problems.
ok well i need to know the size of that elbow. The FFOFH doesn't have provisions for a oil line so you have to put a T in it so you can hook this up. is it 1/4 or 1/8?
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
