Need AWD trans seal part numbers..
Artago
2,094
31
Nov 30, 2006
North Vancouver, BC, Canada
Hi all. I need the part numbers for:
Transmission Input Shaft Seal: MD741818
Transmission Output Shaft Seal: MD723202
Transmission Driver-Side Axle Seal: MD719710
EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM Axle Seal Front Driver Side : Mitsubishi Eclipse 90-99 AWD
Transmission Passenger-Side Axle Seal: MD707184
EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM Axle Seal Front Passenger Side : Mitsubishi Eclipse 90-99 AWD
Transfer Case Input Seal: MD723202
Transfer Case Output Seal: MR983368
Thanks all,
Tom
PS: I have the trans out on my work bench in piece, what else should I be replacing as part of preventative maintenance?
PPS: I'm filling in the info as i find it for others to reference.
I found this
http://www.dsmtuners.com/forums/newbie-forum/257119-here-transmission-part-numbers-we-all-need.html
but it does not include the part numbers for the input & output shaft seals.
Things like synchros, shims to set the pinion tolerances if they are out, input/output seals. Thats about it.
I put double block springs in my 1-2 shift hub, I'll see how much better it is when their worn in.
Also the rubber vent if yours is jacked up, copper washers for the drain/fill bolts. New roll pins for the shift forks. See if there's any wear on your forks, if so replace them.
There's good info on jacks site and I'm sure he would be happy to give you any info you need, he's always very helpful with any questions I have, as well as very knowledgeable about parts.
Looks like your input and reat tcase seals are:
Input: MD731793
Rear: MD701430
I'm actually looking for the transmission seals. The parts you've listed seem to be for the T-Case.
What I need is the Transmission input and output shaft seals.
Do you know what the part numbers are for those?
Thanks,
Tom
I have some spare Mitsu trans seals laying around at home. I'll look at what I have and PM you if you are interested.
Here are a list of the transmission and transfer case seals for 1990-1999 AWD transmissions/transfercases:
Transmission Driver-Side Axle Seal: MD707184
Transmission Passenger-Side Axle Seal: MD719710
You have the Driver side and passenger side numbers backwards. Should be:
See top for complete list and links....
Tom
Tom
NAPA had these in stock, but you have to give them these factory part numbers..If you don't, they don't carry them... :ohdamn:
