Need an answer to a question ASAP!!!!!
Numba1cuban
56
Jan 10, 2005
Miami, Florida
Is the 6 bolt flywheel for the N/A the same thing as the turbo one? I want to know this because i got a 95 gst and am doing a 6bolt swap but want to know if the N/A 6bolt flywheel will fit my 95 gst tranny. I really need to know this immediatly.
Thanks
From what i know the NA 4g63 are all 7 bolt.even if it is 6bolt,the NA motor has high compression pistons,which means you won't be able to turn up the boost over 10 psi,unless you have some serious tunning done.
I think you missunderstood my question. I know the engine differences but wanted to know about the flywheels. I couldnt find anything on the forum or the vfaqs.
thanks for the answer. can anyone else please confirm this?
thanks alot blueman
