Need a new throttle body
seminoles2005
136
Nov 17, 2003
sfield, Kentucky
well my throttle body was leaking when i did a boost leak test, when i tried to remove the screws in the center that holds the throttle plate they stripped while trying to remove them so i tried to extract them out and i got one out but the other one would not budge, i finally drilled it out completely but i damaged the plate doing so.
Ive read that the nt throttle bodys have the same throttle plate size but you only use one gasket. I looked around in a local junk yard and couldnt find any nt 4g63 throttle bodys but i found a 94 galants throttle body that looked like it would be perfect but it didnt have the throttle switch telling the ecu when its open or closed.
Can anyone tell me what model cars carry the larger sized throttle body that i can use to bolt up to my car?
ehh, thats a bit pricey for me, id rather spend 25 dollars on a junk yard throttle body and 5 bucks on o-rings, just wondering which cars would have the throttle bodies i can use
Sorry to thread jack, but I am in need of a TB also and am planning on gettin the 1g 63mm. I shouldn't have any problem runnin that on my 2g would I?
