Need a little advice....
Aurora-Hybrid
165
Sep 6, 2004
Aurora, North Carolina
I have a question.... In my NT/T conversion I have to swap the computers. Does anyone know if the computers wiring harnesses are the same? Or do I have to change the wiring harnesses out along with the engine? I could really use someones input before I get under the hood and get to work. :dsm: :thumb:
as long as you use a 91+ computer it should be the same mine was a 91 and i used a 91computer and it works flawlsly. you will have to ad like 4 wires to the harness; the 7th wire from the maf, knock sensor, fuel pressure soilnoid, boost control solinoid. you will also have to wire in the injector resistor pack. it isn't all that hard if you need any help fel free to p/m me
