N/T tranny on Turbo engine
92blutalon
186
Dec 7, 2008
bridgeview, Illinois
ok i have a N/T engine and i am going to swap a turbo engine in there is there anyway i can retain my N/T tranny??
In other works will the N/T tranny bolt up to a turbo engine
It will work. You will have to use the NT flywheel and PP.
For general info: The NT gear ratio is shorter and the gear set is a little weaker but will last awhile. Also, If you have a 93 or 94 trubo car you will have to swap to the smaller axles.
