n/t ecu in a turbo will it work?
fasteclipse1992
786
Jan 17, 2003
joplin, Missouri
far as it actually working i know it probably wont but i cant get a turbo ecu locally to test out to see if my ecu is bad but i can get a n/t 2.0 ecu. if my ecu is bad will a n/t ecu work for me to see why im not getting a spark. will a turbo engine run with a n/t ecu?
It may run, but not very well, and not saftely.
The NT ECU doesn't have pins for the knock sensor, boost gauge, wastegate solenoid, and fuel pressure solenoid. More importantly, the NT ECU has entirely different fuel and timing maps, so it's not going to run very well if at all with turbo parts.
