My Impossible mod Sirius Performance
MuscleTuner
Mar 2, 2011
west jordan, Utah
This is my custom work i made an adapter plate and all the necessary mods for fitting a tdo5 twin scroll 16g evo 8 turbo on my 95 mitsubishi eclipse. The best part is i kept all the stock components except for the fan in front of the turbo i am the only one that i know of so far to keep all the stock components it can be done heres the proof, finally pictures, enjoy.
I would love to run a twin scroll EVO X turbo and put the 20G wheel in it. That way I have a really fast spooling turbo for down low with the power goals that I want up top.
I didn't think about it untill I had already bought my FP turbo manifold.
I like what you did though, that bracket is crazy. Maybe sometime you'll be able to make another to move the turbo closer to the block... maybe.
I don't see anything done to the manifold. Did you have to customize it at all? I'm not to educated on the EVO exhaust ports. In the picture it looks as if it just bolted right up.
I made the adapter plate so i didnt have to modify the mani or turbo it fits just perfect it couldnt have fit any better with all the clearance issues i dont think i could move it closer to the block.
And yes i do have the full benefits of a dual scroll setup with my divided manifold and special adapter plate it works great.
I havent driven it too much yet but ive seen full 8 psi by 2800 rpms it spools ridiculously quick i love it its like nothing ive driven it starts to spool about 23 or 2400 rpms great turbo
I have an automatic too so i keep a full 8 psi all the way through the band constant spool and power
i forgot to add too that the evo mani bolts right up to the head perfectly
  • Wanted 6 bolt NT water pipe
    • chrisman287
