My first log
vtracer20
407
Oct 1, 2004
Milton, Vermont
Whoops had my thread in teh wrong section:
Okay is my first log i did on the highway in 3rd gear.
ERPM KNCK TPS EGRT O2-R TIMA
3500.00 0.00 76.08 228.00 0.97 15.00
3562.50 0.00 72.16 228.00 0.97 15.00
3687.50 0.00 71.76 228.00 0.97 16.00
3781.25 0.00 71.76 228.00 0.97 16.00
3875.00 0.00 71.76 228.00 0.97 17.00
3937.50 0.00 71.76 228.00 0.96 17.00
4062.50 2.00 71.76 228.00 0.96 18.00
4125.00 1.00 71.76 228.00 0.96 17.00
4281.25 1.00 71.76 228.00 0.96 17.00
4406.25 0.00 71.76 228.00 0.97 17.00
4468.75 0.00 71.76 228.00 0.96 18.00
4531.25 0.00 71.76 228.00 0.96 18.00
4625.00 0.00 71.76 228.00 0.96 18.00
4718.75 0.00 71.76 228.00 0.96 18.00
4812.50 0.00 71.76 228.00 0.96 18.00
4843.75 0.00 71.76 228.00 0.96 19.00
4937.50 0.00 71.76 228.00 0.96 19.00
5000.00 1.00 71.76 228.00 0.96 19.00
5000.00 0.00 71.76 228.00 0.96 18.00
5187.50 0.00 71.76 228.00 0.96 19.00
5281.25 0.00 71.76 228.00 0.96 20.00
5281.25 0.00 71.76 228.00 0.96 21.00
5343.75 0.00 71.76 228.00 0.96 21.00
5437.50 0.00 71.76 228.00 0.96 21.00
5500.00 2.00 71.76 228.00 0.96 22.00
5562.50 2.00 71.76 228.00 0.96 21.00
5593.75 1.00 71.76 228.00 0.96 21.00
5687.50 1.00 71.76 228.00 0.96 22.00
5843.75 0.00 71.76 228.00 0.96 23.00
5843.75 0.00 71.76 228.00 0.94 24.00
5937.50 0.00 71.76 228.00 0.94 25.00
6062.50 0.00 71.76 228.00 0.94 24.00
6125.00 0.00 71.76 228.00 0.94 24.00
6156.25 0.00 71.76 228.00 0.94 24.00
6125.00 0.00 71.76 228.00 0.94 23.00
6250.00 0.00 71.76 228.00 0.94 23.00
6312.50 0.00 71.76 228.00 0.94 23.00
6375.00 0.00 71.76 228.00 0.94 22.00
6406.25 0.00 71.76 228.00 0.94 22.00
6593.75 0.00 71.76 228.00 0.94 20.00
6531.25 0.00 71.76 228.00 0.94 20.00
6593.75 0.00 71.76 228.00 0.94 22.00
6656.25 0.00 69.80 228.00 0.94 20.00
6656.25 0.00 68.63 228.00 0.94 21.00
6812.50 0.00 68.24 228.00 0.94 20.00
6812.50 0.00 10.59 228.00 0.94 21.00
228.00 0.45 45.00
i'm not exactly sure what i'm looking or weather or not these are good numbers. i'm running rich all thet ime and i dont know why, i'm getting horrible gas miliage and after i replaced my fuel filter my miliage jumped 50miles on a tank and now it's back down to around 200miles to a tank. I'll have to do another run sometime this week but can someone tell me wither or not this is good...i'm running 93 octane in the car and i see i have like no knock which might say i'm running super rich someone take a stab at it
oh yeah and how do u start palmnstien software so it logs? all i get into is the menu where i select OBD 1- 1st gen and i can go anywhere else. thanks
Ya besides the TPS being around 71% open, everything looks good..your timing is almost perfect..should try get everything as close to 15 as you can without going under...so in the higher rpms you can lean it out a very small amount
(i would fix the cable and do a WOT run...things might change)
cool..that's good to hear, i gotta wait till the roads dont have snow on them before another run....i thing that concerns me is when i'mjust crusing andi barely tap the accelorator my fuel mixture goes to .93 with out much press on the gas peddle?
here they are..and yes i'm running @ 12psi and will probably turn it up to like 14-15
ERPM KNCK TPS O2-R TIMA
2656.25 0.00 81.18 0.53 27.00
2687.50 0.00 85.49 0.55 22.00
2750.00 0.00 85.88 0.55 19.00
2812.50 0.00 87.06 0.57 17.00
2843.75 0.00 87.45 0.58 16.00
2937.50 0.00 87.84 0.60 14.00
2968.75 0.00 87.84 0.62 15.00
3062.50 0.00 88.24 0.64 15.00
3125.00 0.00 88.24 0.64 14.00
3187.50 0.00 88.24 0.66 14.00
3250.00 0.00 88.24 0.68 14.00
3312.50 0.00 88.24 0.70 15.00
3406.25 0.00 88.24 0.72 15.00
3468.75 1.00 88.24 0.72 15.00
3562.50 0.00 94.12 0.74 15.00
3656.25 0.00 95.29 0.76 15.00
3750.00 0.00 96.86 0.78 16.00
3843.75 0.00 97.25 0.78 17.00
3968.75 0.00 97.25 0.80 17.00
3968.75 0.00 97.65 0.80 18.00
4125.00 0.00 98.04 0.82 18.00
4125.00 1.00 98.43 0.84 18.00
4218.75 1.00 98.82 0.84 17.00
4375.00 0.00 98.82 0.86 17.00
4468.75 0.00 99.22 0.86 18.00
4531.25 0.00 99.22 0.88 18.00
4625.00 0.00 99.22 0.88 18.00
4718.75 0.00 99.61 0.90 18.00
4843.75 0.00 99.61 0.90 19.00
4906.25 0.00 99.61 0.92 19.00
4968.75 0.00 99.61 0.92 19.00
5000.00 0.00 99.61 0.92 19.00
5093.75 0.00 100.00 0.92 20.00
5187.50 0.00 100.00 0.94 20.00
5250.00 0.00 100.00 0.94 21.00
5281.25 0.00 100.00 0.94 21.00
5437.50 0.00 100.00 0.94 21.00
5437.50 0.00 100.00 0.94 22.00
5500.00 0.00 100.00 0.94 22.00
5625.00 0.00 100.00 0.96 22.00
5687.50 0.00 100.00 0.96 23.00
5625.00 0.00 100.00 0.96 23.00
5781.25 0.00 100.00 0.96 23.00
5875.00 0.00 100.00 0.96 23.00
5812.50 0.00 100.00 0.96 24.00
6000.00 0.00 100.00 0.96 24.00
6156.25 0.00 100.00 0.96 24.00
6093.75 0.00 100.00 0.96 22.00
6156.25 0.00 100.00 0.96 23.00
6250.00 0.00 100.00 0.96 23.00
6281.25 0.00 100.00 0.96 22.00
6343.75 0.00 100.00 0.96 22.00
6375.00 1.00 100.00 0.96 21.00
6468.75 1.00 100.00 0.96 21.00
6437.50 0.00 100.00 0.96 20.00
6500.00 0.00 100.00 0.96 20.00
6468.75 0.00 100.00 0.96 20.00
6531.25 0.00 100.00 0.96 20.00
6625.00 0.00 100.00 0.96 20.00
6656.25 0.00 100.00 0.96 20.00
6750.00 0.00 100.00 0.96 20.00
6593.75 0.00 100.00 0.96 20.00
6718.75 0.00 100.00 0.96 20.00
6843.75 0.00 100.00 0.96 19.00
6781.25 0.00 100.00 0.96 19.00
6843.75 0.00 100.00 0.96 20.00
6812.50 0.00 100.00 0.96 19.00
6906.25 0.00 100.00 0.96 19.00
3750.00 1.00 89.41 0.96 16.00
3843.75 1.00 89.80 0.96 16.00
3937.50 0.00 89.80 0.96 17.00
3906.25 0.00 89.80 0.96 18.00
4000.00 0.00 89.80 0.96 18.00
4125.00 0.00 89.80 0.96 18.00
4156.25 0.00 89.80 0.96 18.00
4218.75 0.00 89.80 0.96 18.00
4312.50 0.00 89.80 0.96 18.00
4343.75 1.00 89.80 0.96 18.00
4500.00 1.00 95.29 0.96 17.00
4531.25 0.00 97.65 0.96 17.00
4468.75 0.00 98.82 0.96 18.00
4593.75 0.00 99.61 0.96 18.00
4687.50 0.00 100.00 0.96 18.00
4750.00 0.00 100.00 0.96 19.00
4812.50 0.00 100.00 0.96 19.00
4875.00 0.00 100.00 0.96 19.00
4937.50 0.00 100.00 0.96 19.00
4968.75 0.00 100.00 0.96 19.00
5125.00 0.00 100.00 0.96 19.00
5156.25 0.00 100.00 0.96 20.00
5281.25 0.00 100.00 0.96 20.00
5250.00 0.00 100.00 0.94 20.00
5375.00 0.00 100.00 0.94 21.00
5562.50 0.00 100.00 0.94 21.00
5593.75 0.00 100.00 0.94 22.00
5625.00 0.00 100.00 0.94 22.00
5718.75 0.00 100.00 0.94 22.00
5718.75 0.00 100.00 0.94 23.00
5781.25 0.00 100.00 0.94 23.00
5875.00 0.00 100.00 0.94 24.00
5875.00 1.00 100.00 0.94 24.00
5937.50 0.00 100.00 0.94 23.00
5906.25 0.00 100.00 0.94 24.00
5968.75 0.00 100.00 0.94 24.00
6062.50 0.00 100.00 0.94 24.00
6031.25 0.00 100.00 0.94 24.00
6187.50 0.00 100.00 0.94 23.00
6125.00 0.00 100.00 0.94 23.00
6156.25 0.00 100.00 0.94 23.00
6218.75 0.00 100.00 0.94 23.00
6218.75 0.00 100.00 0.92 22.00
6343.75 0.00 100.00 0.92 23.00
6250.00 0.00 100.00 0.92 22.00
6281.25 0.00 100.00 0.92 21.00
6406.25 0.00 100.00 0.92 22.00
6343.75 0.00 100.00 0.92 21.00
6468.75 0.00 100.00 0.92 21.00
6500.00 1.00 100.00 0.92 22.00
6531.25 1.00 100.00 0.92 20.00
6468.75 0.00 100.00 0.92 20.00
6562.50 0.00 100.00 0.92 20.00
6562.50 0.00 100.00 0.92 21.00
6656.25 0.00 100.00 0.92 21.00
6718.75 0.00 100.00 0.92 21.00
6625.00 0.00 100.00 0.92 20.00
6687.50 0.00 100.00 0.92 21.00
6812.50 0.00 100.00 0.92 20.00
hey ihave a ? though...i was wondering at idle is my TPS suppose to be like 10% or at zero? also i dont see knock which is good but when i look at other people's logs they have knock alot more than i do. Please comment of the last two logs plz thanks
