My first log
mitsuclipsegsx
2,561
8
Apr 5, 2004
Dover plains, New York
Just got my m 105 everything is working fine except 2 things, on my list on my palm 02 voltage is not one of them? i have a arrow at the bottom to like go lower, but it wont??? and which 2 determines knock?
Calculated Load
Coolant Temperature
Short Term Fuel Trim Bank X
Long Term Fuel Trim Bank X
Fuel Pressure (Gauge)
Intake Manifold Absolute Pressure
Engine RPM
Vehicle Speed
Ignition Timing Advance
Intake Air Temperature
Air Flow Rate from MAF
Throttle Position
Oxygen Sensor Bank X Sensor Y
You need to log timing to determine if you are getting knock. I would log RPM, Ignition timing and Oxygen sensor (the last one on your list). The O2 Voltage is logged from the oxygen sensor. At least on pocketlogger it is.
From these three values you should be able to get a pretty good feel of how rich, lean or approx. how much knock, by seeing if your timing is being pulled during a 3rd gear WOT pull to redline.
thats what i am saying i cant get to 02 voltage it has the arrow to go down but wot let me :confused:
Just keep clicking around the arrow and it will go down, sometimes the touch screens are abit out of whack.
