my first data log
nick
154
Feb 13, 2006
Edmonton, AB, Canada
Hi guys. Just got my mmcd data logger today in I did my first log. Car mod..3"gm maf-t, 3 turbo back, k&k air filter,stock injector and running 12 psi..
IDLE..
RPM...843
INJD...1.5%
KNCK...0
02-R...0.07V
TPS...10.1%
MAP...2.77bar
TIMA...10deg.
COOL...69.0deg
AIRT...25.6degC
BARO...0.99ms
BAT...14.0V
ISC...56
FTRL...81.2%
FTRM...100%
FTRH...98.4%
FTO2...100%
MAFS...56Hz
ACLE...0.0%
FLGO...-SA-I
FLG2...-FB
MAP...0.75bar
OILP...1.04atm
EGT...9
OILT...32
FUEL...1.04atm
WBO2...56
PLEN...128
PUMP...0.3V
4343 RPM......
RPM...4343
INJD...3.9%
KNCK...4
02-R...0.09V
TPS...50.0%
MAP...2.77bar
TIMA...29deg.
COOL...69.0deg
AIRT...25.6degC
BARO...1.00ms
BAT...13.80V
ISC...101
FTRL...81.2%
FTRM...100%
FTRH...98.4%
FTO2...100%
MAFS...589Hz
ACLE...0.0%
FLGO...--A-I
FLG2...-FB
MAP...0.52bar
OILP...0.03atm
EGT...17
OILT...32
FUEL...0.23atm
WBO2...24
PLEN...145
PUMP...0.3V
Are this readings ok..If not what are the reading should be???
Do you have a MAP wired in? Its showing 2 maps with different readings (mmcd throws odd numbers out for values not set up). From the looks of this your higher rpm log is pulling a lot of fuel in your low and high trims, but your only at 50% throttle. If your running stock boost, on a stock injector (stock pump?), why use a gm maf?
I'm running 3" gm maf-t coz I'm planning to put a 650cc injector, 190 pump in and a 16g turbo.. Have a fmic and a hks bov as well..Don't have the map wired coz I'm using the gm maf-t to adjust the air and fuel..My wideband reads at 14.7 at idle 10.1 on wot 10psi ocz I have a boost leak from throttle body shaft..
Since your in a 1g and have a WB and all the other accessories, Id mainly keep an eye on knock and tuning for knock at WOT. The other information from mmcd, since its not adjustable through the program, is only good for checks and balances. It looks pretty standard for idle and cruise. Your ISC counts are a little high, does it surge? You mentioned boost leaks, that could be a cause. Still might want to run through a biss adjustment if isc counts at idle, when up to temp, dont go any lower. You were still warming up on that log. Id try to get the fuel trims in line to =100% +/- 5 or so.
Maybe someone on here can point you in the right direction with maft tuning, as Ive steered clear of the gm mafs. Just reset your ecu so your trims zero out after adjustments and see where they take you.
Thanks Dude Mcnee. I'm still waiting for the tb shaft seal to fix the leak. I haven't done that much tuning yet, not till got all the leak fix...The timing look ok to you? Seems like it move too much..
