My drivetrain issues, what is going on?
davetheman81
163
Jun 16, 2010
randolph, Massachusetts
Hey guys and girls im a newb to drive shafts and i was hoping someone might shed light on this issue. Well since the build i have been having many drive train issues, it all started when my t case seized up, i was doing about 10 mph, i had bruce replace it and the seal and he checked the center diff and the shaft had no play or gouging in it. I then noticed my yolk was leaking so i replaced the whole drive shaft with a better looking driveshaft and new yolk, and put in a 4 bolt rear end. Ever since then i have always noticed a ratle/scrapping sound in the rear end only during constant speed, it would disapear with acceleration and deceleration, i removed the fluid from the rear end last night and it was clean, and replaced it again. Then took a drive and mysteriously now i get a scrapping ratle noise from the frnt end to now, sounds like its directly under were the passengers nees would be, it sounds like a garden rack on pavement somewhat, this noie how ever only shows it self staying a certain speed like the other noise but also inbetween shifts, and last there is a suttle whine from under the car for the first 1k rpms in1st and 2nd gear. The exhuast or any heat shield is not scrapping but i did notice the driveshaft carrier bearings are completly trashed, you can move the driveshaft about .5 inches in any direction, could this becouse the driveshaft to have backlash and make the car make these noises? If not any idea? Thanks
  • For sale 2g 2G Eprom ECU
    2G Eprom ECU $195 + shipping & paypal feesYou must be registered to see element.You must be...
  • Wanted 1g WTB: '90 PTU
    Does anyone have a '90 PTU lying around? Part #md127742. Checking here before I buy one from...
    • Gabe92RTTT
  • For sale GVR4 Rare HKS Hi-Flow Intake Kit
    Rare HKS Hi-Flow Intake Kit $165 + shipping & paypal fees* For GVR4, but can also use on 1G *...
  • For sale 1g NEW Fidanza 6 Bolt AWD Flywheel
    NEW Fidanza 6 Bolt AWD Flywheel $250 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 Dejon Intake ( recirc )
    Dejon Intake ( recirc ) $90 + shipping & paypal feesYou must be registered to see element.You...
