My compression test results
BurrowZ
836
5
Nov 28, 2010
Duluth, Minnesota
Alright, I've been having trouble with hot starts and cold starts. Both take a few tries and on hot starts I have to give it gas to keep it alive. Mods are up to date, I haven't thrown a solid tune on DSMLink v2 yet but just good enough to get it running safely.
Anyway.
2G stock 7 bolt block - 98k
1G head unknown mileage
HKS 264/272 cams
BC valve springs
NO boost leaks
-8in/hg @ 800rpm idle
Harbor freight compression test results:
120 EXACTLY on EVERY cylinder. Tested three times.
I will do a leak down test sometime this week if I get a chance.
My questions:
Do cams with a duration such as mine lower the compression test results?
Will a tired/slow starter affect the results?
-8in/hg seems excessively low to me, is this correct though?
When I changed the valve springs I didn't bleed the lifters or anything, will this cause low compression test results?
Thanks in advance to those who help!
Try bleeding the HLAs, when the cams are removed, they pump up a touch.
When the cams are installed back in the head, it may cause the valves to crack off the seats a touch lowering compression.
Also verfiy your timing belt marks to make sure you are not a tooth off
I should have mentioned timing is dead on, that was my first check.
I will try bleeding the lifters soon, do I just follow this write up?
http://www.dsmtuners.com/forums/articles-engine-fuel/265060-how-replace-lash-adjusters-lifters.html
If so, I don't have pry bars (STUPID NOOB!) so I'll have to grab some tomorrow and give it a shot.
I normally put a battery charger on to charge battery up between tests which keeps test results consistent. Example, no charger I got 140psi then 135, 130, 125. Something scary like that. Then retested with charger and same time between tests, I got 150psi +/- 2psi.
Cam overlap will effect test results but I'm not sure about your cams.
Go to the compression test / leak down testing thread made be Calan for more info on that
