my car won't stay running
damianretana
Nov 2, 2007
dallas, Texas
ok I have an 95 eagle talon tsi awd I had problems with my computer and now that I order other ecu the car starts stays at 700 rpm for 5 seconds and dies and when i try to rev it up a little the rpm instead of going up it goes down and dies I replace cps .ignition module, coils , crank position sensor , fuel pump, fuel pump relay , and still don't know what is happening.
I will apreciate any help.:confused:
I doubt it is something as simple as this (since it sounds like you've been working/replacing many things so I'm sure you would have noticed it before), but just incase... double check that your wiring harness for the MAF is plugged in all the way. I had the same issues you described after doing some work on my car and I hadn't fully snapped the harness together. Like I said...this probably isn't your problem, but it never hurts to double check. Good luck.
Edit: robbo185 beat me to it.
