my car is cutting out anything over a 1/4 throttle
ohh LOL. i was going on a road that goes up and down really fast, catching some air to a lil scary but when ya got girls with ya things get crazy.. well id look at the map sensor if i knew where it was and wut it looks like.. where is it LOL?
i have no idea if their is the portfuler setup with it. the guy i bought it from had all the work done to it..... how would i know if it had one.. and how do u know its hahn turbo??? the car also has a hahn racecraft sticker on it so idk..
Because it has the Hahn IC Pipes, the Hahn Log Manifold, And a Mitsubishi Turbo... Probably a lil 16G. That entire setup is HRC Stage 1.
The Portfuler is a little plate that bolts in between the head, and the intake manifold, that carries 4 aditional, oversized injectors. That way under normal driving conditions, your stock injectors are the only ones working... and when under boost, the bigger injectors have some fun.
im thinking i need a portfueler set up or new injectors. even though i can give it full throttle its still boggin down a lil bit, and my quarter throttle is just as fast ironicly.
Why does everyone have to make a comment when something's been moderated?
The only way to make a 2.3L stroker is to de-stroke a 2.4L -- although I've never heard of that being done. I have, however, seen a 2.5L stroked 2.4L. Anything's possible with enough money and resources, but nothing in the included pictures is indicative of a 2.4L swap.
the guy has the receipts of everything done to it. i just have to get them to show proof of it LOL. the guy did none of the work him self he said he took it into redline and had it rebuilt, had them put the turbo in, and the 2.4 stroker kit. other then that idk.
The fact it is a 2.4L or not is not the reason for the post.
The fact that you need to STILL update your profile is one of the reasons you have 42 posts in this thread and not a single solution. Please tell us how you are stopping fuel cut, what kind of FMU are you using, how much boost, what size injectors... We need information to be able to help you; you seem to not need or want the help.
This post seems like a dead end to me; 42 posts and you haven't fufilled our first request as to what YOU have to do to to solve the issue at hand.
Yeah, I'm still mind boggled about the problem. He's now describing the problem is gone? Sure if he had fuel issues it could have been the pump, but he still had issues afterwards. Until his battery cable fell off... Now the issues are gone?
I understand now, instead of fuel cut we need to drive the car and pull one of the battery terminal cables. That will solve the problem; rod knock? No problem. Piston through the hood? No problem. You name it we can fix it.
id say their is still a problem.. when my car is idling its at only 5lbs of vacuum when before it would be at like 18 or 20. idk if its ### the turbo is messing up or the computer is controlling it or what....
anyone??
anyone??
How many times must you be asked to follow the grammar policy?
sorry i have bad grammar..
You need to learn to not talk back to mods. To participate on this forum site you MUST have proper grammar.
You also need to list EVERYTHING in your setup. You did not list enough information.
If you do not know what size your injectors are, I would suggest you start there; the stock injectors are either 195cc or 220cc IIRC; therefore, you will not be able to run more than 2-3psi of boost. I would get on one of our sponsors sites and order some bigger injectors or go on ebay and buy some injectors 550cc injectors are common for most 420A-t's.
:toobad:
