My 99 GSX.......what to do????
Justins99GSX
246
3
Oct 31, 2004
Somewhere, Arizona
Hey there...i am a little new to the dsm but i have done quite a bit of research on this site.....this is my setup right now:
--GReddy Hard pipe kit w/ type S blow off valve :thumb:
--Full 3" Exhaust no cat and GReddy 3" Muffler
--GReddy E-01 Boost controller
--K&N Akimoto 4" Intake Filter
The main question I have is that i can't seem to properly tune the E-01... i tried the auto mode but reguardless of how much i turn it down i can't seem to get any lower that 14 psi :confused: I now have it in manual mode and i was wondering if anyone can share their numbers (Gain, Set, And Start Settings).... I managed to hit 18psi with the set at 50% and the Gain at 15 with the start setting at 4psi...Also wondering what i should get.....DSM Link or E-manage..... :dsm:
Justin :dsm: :talon:
well you wont be able to set it much lower than 9-11psi because of the internal wastegate spring is set around there... but whats wrong with 14psi thats a good setting for your little T-25
if you are using the E01 you might as well get the E-manage as they are made for each other. You can use the E01 insted of a laptop when tuning the E-manage. If it were me I would just get rid of that electronic crap and make a manual boost controller.. then use DSMlink. So.. if you like the E01 and want to use it get E-Manage.. if you think you would want something more simple get a MBC and DSMlink.
  • Wanted 6 bolt NT water pipe
    • chrisman287
