motor to tranny bolts
Dr Vic
107
Aug 30, 2007
Dallas, Texas
hi
can any one describe the 4 bolts that hold the motor and transmission together? I asked this question before and my guess is I only have 2. I just need to know what head size they are and/or length.
vic
I don't know if it is any different on a 1g, but i wouldn't think so. But on mine there were two on top, 2 in front, and one on the back underside if I remember right.
there 4 sizes total........the two shortest i believe either a 17mm 0r 15mm go on top....the third bolt that has the same head size as the two on top but longer goes in the front dowel spot and the smaller bolt goes in bottom rear dowel spot. the two bolts for the starter are exactly the same i believe they were a 14mm..
i just pulled my awd trans and about a min ago put it back in.
Hopefully this helps.
Directly from VFAQ.:thumb:
Use it its your friend.<a href="http://img291.imageshack.us/my.php?image=boltsdt7.gif" target="_blank"><img src="http://img291.imageshack.us/img291/4325/boltsdt7.th.gif" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a><br /><br /><a href="http://img604.imageshack.us/content.php?page=blogpost&files=img291/4325/boltsdt7.gif" title="QuickPost"><img src="http://imageshack.us/img/butansn.png" alt="QuickPost" border="0"></a> Quickpost this image to Myspace, Digg, Facebook, and others!
does any body know how to take that damn speedometer out of the trans? Ive tried screwing it out (towards the left) but the part where the bolt goes into is hitting part of the trans. do you twist it to the right?
which part screwed off? did you just twist it to the left or right? i need a vice grip to be able to turn mine
standing infront of car twist to left to break loose and of course teist right to tighten..maybe spray some wd40 on her
  • Wanted 6 bolt NT water pipe
    • chrisman287
