Mostly stock 1G N/T. Stock replacement clutch or Centerforce DF?
dj_zero
86
Sep 4, 2004
Byram, New Jersey
Hey, first thing, I wouldn't even be considering the centerforce, except that at nopi, it doesn't cost too much more than the stock replacement, so what the hell. The car is mostly stock and it's going to stay that way, so I don't really *need* any stronger clamping force. But:
Would I feel any increase in power if I went with the centerforce, since it supposedly clamps harder?
And also:
Would the centerforce last as long under normal use?
your not going to gain any power with a different clutch.id go with the stocker,and i havent heard too many good things about df clutches.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
