More clutch disengagement probs
TransAmConvert
43
Dec 16, 2004
Pittsburgh, Pennsylvania
Yes I know this has been covered eleventy billion times, but bear with me anyway.
I have
ACT 2100
New slave cylinder
Braided clutch line
The clutch is having trouble disengaging. If I bleed it, it works GREAT for a while, but within a couple of days it gets progressively worse and won't disengage again. The floor by the master is dry and I cant find any leaks in the line. I really don't want to change stuff I dont have to, and this is only a 2100. Does anyone have any ideas of what might be amiss?
does the level of your fluid slowly get lower? if not you don't have a leak.
i would recomend adjusting you clutch engagment point. you might need to adjust the rod the connects the clutch peddal and master cylinder.
Im going to agree with SPLN HRD. My first reaction would be a leak in the line somewhere. Maybe the pedal needs to be adjusted but what your describing sounds more like air getting in the lines somewhere.
