Missing the Arp manual!
defeat54
50
Oct 18, 2011
MONTGOMERY, Alabama
As the title states, I'm missing my owners manual for my Arp head studs & main studs. If you know the torque specs using motor oil your help would be greatly appreciated.
I did some research and found mixed information.
use the lube that came with the studs, if you dont have it you can find it online. I used my original manufacturers torque specs and everything is ok, i just put the stud in by hand and then give it a 1/4 turn with a alan wrench.
also you should try to visit arp website they might give you directions there.
Its for a 420a Turbo. I don't have the the ARP lube because this is a rebuild.
They didn't specifiy torque specs with my instructions. They prefer their lube and factory specifications in a 3 step torque route. Oil can be used but they note that torque may be inconsistent.
  • Wanted 6 bolt NT water pipe
    • chrisman287
