missing at idle and slight throttle
stevetalon
135
Aug 1, 2007
Frederick, Colorado
what will cause misses at idle and slight throttle.I think this started when i took off the egr and replaced the cas. I have new plug wires and recently put new plugs on. If my timing was off a little would this cause this and can a boost/vaccum leak cause this?
Start with the cheap/easy stuff.
first make sure your plugs are gapped right - free
next boost leak test.
If you don't know how theres a writeup on the vfaq and how to make the tester - under $10
those would be the first 2 things to check
checking your timings a b*tch the first time so nock off the easy stuff first.
