misfiring troughout RPM range
Cam timing is dead on in relation to what? The timing belt could have skipped down on the crank but the cams would still line up with each other. Rotate the crank pulley so that your notch is at BTDC and then check your cam marks.
Where ever the mark indicating BTDC is. I have not had to look in a while so honestly I cannot remember exactly what it looks like.
Do you have a fuel pressure gauge on your afpr? If so you may want to check to see if you frp is adjusting properly. If your plugs were black, it is running rich. Your regulator may be raising the pressure to high. Also you may want to add another ground wire. If your not getting enough ground the computer may be trying to compensate for the loss, and add too much fuel.
According to the OP his compression is only 90-95 psi. If the compression test was performed accurately then this is his problem. He needs to be chasing down reasons for such low compression such as blown head gasket, incorrect cam timing, stretched head bolts and etc.
Am i sumpoose to only have cylinder 2 and 4 injectors working while cranking the engine?[/QUOTE]
You should have fuel coming from all 4 injectors while cranking.
Also if you are spraying carb cleaner and it is running better then I would say this definitely sounds like you are not getting fuel from one or more injectors. This is making up for the fuel you are not getting and allowing it to run smoother.
like i said before, do it by the book.
try these things (after maintance if you havent done any in a while, for example new plugs) i suggest in this order.
1: check spark
2: check fuel delievery
3: check compression. compression for the 2.0L is 180-255 AFTER 5 CRANKS!!!!
(seems there is alot of people on here who dont understand when doing a compression test you NEED to crank it 5 times per cylinder.)
if everything checks out then re time it. common problem for sputtering and missing.
if that doesnt solve it, check clogged or clogging, or fualty, injectors
if nothing still check for a sticking valve. ( that was the problem with mine, before i decided to rebuild my head in my bed room.)
EDIT: checking your fuel delivery involves checking to see if your getting electricity to the injector, make sure they the electrical plugs are tight on the injectors. use a Volt Meter or a Current Checker to see if your getting electricity.
1: check spark
OWNED by reading.........jesus come on now
