Meth kit questions
Supa Dexta
452
Sep 12, 2007
Edm,
A couple of things have come up for installing a snow kit, for instance> If no solenoid is used (as stated by snow the solenoid is only for if the nozzle is mounted in the manifold to prevent siphoning in vac, or if the line/tank/pump is higher then the nozzle to prevent it from draining into the intake) So what stops it from acting as a boost leak? Will no pressure go back thru the pump itself? As when the pump is on it has it's 150psi to fight back with, when not powered it would seem as an open escape...
Also, they say to mount the pump at the same level or lower then the reservoir, is that only to make it "easier" on the pump? It's not as if it needs to be gravity fed, so really the only reason I can see for that is getting primed to begin with. Thoughts,
Forgot about this, from snow> the pump has a check valve within that prevents it from acting as a boost leak when not powered up..
And for the searches>
Alright, according to this thread:
http://www.dsmtuners.com/forums/arti...-meth-kit.html
(pin 90 on a 2g) that would correspond to pin 10 on a 1g.... I have no idea why there is so little info out there for meth installs, but now we know> that the snow 2d kit maf / mas signal for a 1g is pin 10, on connector c61, strip some wire and hook the yellow wire to it for a maf signal.
Methanol injection - snow 2d - mas - maf - signal - 1g meth signal
  • Wanted 1g Chassis harnes fuse box
    • 92AWDHX40
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
